讨论文章主题﹕软性显示大未来:AMOLED
继TFT-LCD之后,AMOLED被喻为下一世代面板。其中有机发光二极管(OLED)为一固态自发光显示器,具有结构简单、自发光无需背光源、广视角、影像色泽美丽、省电等优势,在中小面板市场可望大幅成长。...
Gordan Hsu
来自: 新竹县市
文章: 2
发 表 于: 2010.11.17 12:22:14 AM
文章主题: 軟性顯示大未來:AMOLED
Do you think Flexible displays will rule the future market?
来自: 宜兰/花莲/台东
发 表 于: 2010.11.17 09:13:20 AM
文章主题: Re: 軟性顯示大未來:AMOLED
應該會 !! 由於簡易攜帶性與可捲曲特性,大大省掉空間:其影像品質、亮度、價格、防水性、耐用耐摔性、省電性、尺寸大小與重量、網路雲端應用、周邊應用...也是觀察要項。
Gordan Hsu
来自: 新竹县市
文章: 2
发 表 于: 2010.11.18 01:23:42 AM
文章主题: Re : Re: 軟性顯示大未來:AMOLED
Adam Chen 提到:
But, who needs a flexible "small" displays? No one wants to see a twist images.
来自: 宜兰/花莲/台东
发 表 于: 2010.11.18 09:02:52 AM
10"以上都算O.K. ,當E-Reader應不錯,但太大如超過50"是否不好攜帶?
发 表 于: 2010.11.24 12:07:09 PM
发 表 于: 2010.12.02 11:19:35 AM
Flexible OLED 3DTV From Samsung Wraps Around Walls...Or Anything, Really
Flexible OLED 3DTV From Samsung Wraps Around Walls...Or Anything, ReallyWe've seen all manner of crazy prototypes involving flexible OLED panels (even one which wrapped around a pencil), but a flexible OLED which just so happens to be 3D? Sign us up for warped Avatar viewing, Samsung. [SamsungOLED via OLED-Display]
发 表 于: 2010.12.08 11:16:02 AM
发 表 于: 2011.01.06 11:42:11 AM
Samsung to unveil next-gen flexible and transparent AMOLED displays at CES 2011
Samsung Mobile Display is set to unveil a pair of next-gen AMOLED display prototypes at CE...
Samsung Mobile Display is set to unveil a pair of next-gen AMOLED display prototypes at CES 2011
There’s bound to be all manner of display technologies vying for eyeballs at CES 2011 when it kicks off in Las Vegas next week and two prototype AMOLED displays from Samsung Mobile Display (SMD) will definitely be high on our list of things to check out. The first is a 4.5-inch 800 x 480 (WVGA) resolution flexible AMOLED display concept prototype for mobile devices, while the second is the world’s largest transparent AMOLED display prototype for use in PC monitors and TVs.
Flexible AMOLED display prototype
SMD’s 4.5-inch flexible AMOLED display is two millimeters (0.08-in) thick and can be rolled down to a radius of one centimeter (0.39-in). The concept prototype’s 800 x 480 resolution, which Samsung claims is four times that of the previous most flexible AMOLED prototype constructed, comes courtesy of a new plastic substrate that can withstand the 450-500 degree Celsius temperatures required in the manufacturing process.
As this overcomes the problem of previous plastic materials melting during the manufacturing process that made commercialization of such devices difficult, Samsung says the concept display on show marks a major step on the road to mass production for the next-gen display, which is aimed at smartphones and tablet PCs.
Transparent AMOLED display prototype
The second prototype display to be unveiled is aimed at larger screen applications such as TVs and PC monitors. The 19-inch transparent AMOLED display prototype sports a qFHD (quad Full High Definition) resolution. This is a non-standard resolution of 3840 x 2160 pixels arranged in a 16:9 aspect ratio that gets its name from being four times the resolution of 1080p.
The prototype display is the world’s first large transparent AMOLED display prototype and, while the average amount of transparency previously achieved has been below 10 percent, SMD’s display maintains up to 30 percent transparency whether it is turned on or off. Samsung says this will allow the technology to be used for surfing the internet while watching TV or even watching TV on windows – and by that it means the glass kind, including car windows, not the operating system.
As well as the 19-inch prototype, SMD will also be exhibiting a 14-inch qFHD transparent AMOLED display designed for notebooks.
(gizmag)
看來flexible Display,日韓也是競爭對手...
发 表 于: 2011.01.10 11:55:01 AM
告別玻璃螢幕CES 2011三星展示可彎曲的的AMOLED螢幕
http://tech.weiphone.com/2011-01-07/Bid_farewell_to_the_glass_screen__229015.shtml
发 表 于: 2011.01.14 11:35:21 AM
全新螢幕技術隱形眼鏡上的超級LED液晶屏
http://tech.weiphone.com/2011-01-13/The_new_screen_technology_229323.shtml
