討論 文章 主題﹕軟性顯示大未來:AMOLED
繼TFT-LCD之後,AMOLED被喻為下一世代面板。其中有機發光二極體(OLED)為一固態自發光顯示器,具有結構簡單、自發光無需背光源、廣視角、影像色澤美麗、省電等優勢,在中小面板市場可望大幅成長。...
Gordan Hsu
來自: 新竹縣市
文章: 2
發 表 於: 2010.11.17 12:22:14 AM
文章主題: 軟性顯示大未來:AMOLED
Do you think Flexible displays will rule the future market?
發 表 於: 2010.11.17 09:13:20 AM
文章主題: Re: 軟性顯示大未來:AMOLED
應該會 !! 由於簡易攜帶性與可捲曲特性,大大省掉空間:其影像品質、亮度、價格、防水性、耐用耐摔性、省電性、尺寸大小與重量、網路雲端應用、周邊應用...也是觀察要項。
Gordan Hsu
來自: 新竹縣市
文章: 2
發 表 於: 2010.11.18 01:23:42 AM
文章主題: Re : Re: 軟性顯示大未來:AMOLED
Adam Chen 提到:
But, who needs a flexible "small" displays? No one wants to see a twist images.
發 表 於: 2010.11.18 09:02:52 AM
10"以上都算O.K. ,當E-Reader應不錯,但太大如超過50"是否不好攜帶?
發 表 於: 2010.11.24 12:07:09 PM
發 表 於: 2010.12.02 11:19:35 AM
Flexible OLED 3DTV From Samsung Wraps Around Walls...Or Anything, Really
Flexible OLED 3DTV From Samsung Wraps Around Walls...Or Anything, ReallyWe've seen all manner of crazy prototypes involving flexible OLED panels (even one which wrapped around a pencil), but a flexible OLED which just so happens to be 3D? Sign us up for warped Avatar viewing, Samsung. [SamsungOLED via OLED-Display]
發 表 於: 2010.12.08 11:16:02 AM
發 表 於: 2011.01.06 11:42:11 AM
Samsung to unveil next-gen flexible and transparent AMOLED displays at CES 2011
Samsung Mobile Display is set to unveil a pair of next-gen AMOLED display prototypes at CE...
Samsung Mobile Display is set to unveil a pair of next-gen AMOLED display prototypes at CES 2011
There’s bound to be all manner of display technologies vying for eyeballs at CES 2011 when it kicks off in Las Vegas next week and two prototype AMOLED displays from Samsung Mobile Display (SMD) will definitely be high on our list of things to check out. The first is a 4.5-inch 800 x 480 (WVGA) resolution flexible AMOLED display concept prototype for mobile devices, while the second is the world’s largest transparent AMOLED display prototype for use in PC monitors and TVs.
Flexible AMOLED display prototype
SMD’s 4.5-inch flexible AMOLED display is two millimeters (0.08-in) thick and can be rolled down to a radius of one centimeter (0.39-in). The concept prototype’s 800 x 480 resolution, which Samsung claims is four times that of the previous most flexible AMOLED prototype constructed, comes courtesy of a new plastic substrate that can withstand the 450-500 degree Celsius temperatures required in the manufacturing process.
As this overcomes the problem of previous plastic materials melting during the manufacturing process that made commercialization of such devices difficult, Samsung says the concept display on show marks a major step on the road to mass production for the next-gen display, which is aimed at smartphones and tablet PCs.
Transparent AMOLED display prototype
The second prototype display to be unveiled is aimed at larger screen applications such as TVs and PC monitors. The 19-inch transparent AMOLED display prototype sports a qFHD (quad Full High Definition) resolution. This is a non-standard resolution of 3840 x 2160 pixels arranged in a 16:9 aspect ratio that gets its name from being four times the resolution of 1080p.
The prototype display is the world’s first large transparent AMOLED display prototype and, while the average amount of transparency previously achieved has been below 10 percent, SMD’s display maintains up to 30 percent transparency whether it is turned on or off. Samsung says this will allow the technology to be used for surfing the internet while watching TV or even watching TV on windows – and by that it means the glass kind, including car windows, not the operating system.
As well as the 19-inch prototype, SMD will also be exhibiting a 14-inch qFHD transparent AMOLED display designed for notebooks.
(gizmag)
看來flexible Display,日韓也是競爭對手...
發 表 於: 2011.01.10 11:55:01 AM
告別玻璃螢幕CES 2011三星展示可彎曲的的AMOLED螢幕
http://tech.weiphone.com/2011-01-07/Bid_farewell_to_the_glass_screen__229015.shtml
發 表 於: 2011.01.14 11:35:21 AM
全新螢幕技術隱形眼鏡上的超級LED液晶屏
http://tech.weiphone.com/2011-01-13/The_new_screen_technology_229323.shtml
關鍵字: AMOLED
Vishay車規級可獨立控光RGB LED支援寬色域控制
花蓮綠電合作社攜手東華大學打造社區太陽光電專業力
巴斯夫電子材料事業處人事調整 以台北為策略營運基地
鈺緯科技30周年三箭齊發 攻高階醫療顯示市場
產學研合力打造高速低耗能雷射源 迎接AI未來之光
公共顯示技術邁向新變革
大眾與分眾顯示技術與應用
使用三端雙向可控矽和四端雙向可控矽控制LED照明
