討論 新聞 主題﹕光纖網路將大開滲透率 新舊建築通吃
資策會與電電公會結合電信業者,於今日(7/8)針對建構全光纖建築舉辦商機媒合活動。現場同時展示位於新莊的全光化寬頻示範點,資策會表示,光纖可以串連有線電視、網路電話、監控系統等家庭影音,政府帶頭示範,未來無論是新成屋或舊建築,光纖網路的滲透率都將大開...
發 表 於: 2010.07.09 12:04:26 PM
文章主題: 光纖網路將大開滲透率 新舊建築通吃
【台灣光纖普及率 要超越韓日---轉述 udn 】 資策會FIND資料顯示,截至2009年上半年,台灣光纖家戶普及率達19%,名列全球第四,僅落後南韓、日本與香港。官員認為,台灣土地小、人口密集,光纖普及率應可超前南韓與日本。
發 表 於: 2010.07.28 11:19:16 AM
文章主題: Re: 光纖網路將大開滲透率 新舊建築通吃
Intel's Optical Breakthrough Downloads an HD Film in a Second, Literally
Intel's Optical Breakthrough Downloads an HD Film in a Second, LiterallyTransfer a song to your phone. Seems pretty fast, right? Now imagine transferring the entire printed catalog of the Library of Congress in a minute and a half. Intel says they've got the technology to make it happen (eventually).
Intel detailed their breakthrough to the press at an event today, marking the milestone of impressive 50 gigabits per second transfer speeds using an underlying technology that could go much, much further. We've covered the promise of fiber optic speeds before, but nothing like this. Intel CTO Justin Rattner explained just what "silicon photonics" even means, why the world needs it, and what it promises in the near future.
Silicon photonics is, simply, the combination of optical technology with traditional silicon chip manufacturing techniques—the same processes used to make all of our CPUs and GPUs. By employing existing methods, turning data into light and back again will be affordable.
The fundamental process is that of transferring data by converting electrons—which are what make the device you're reading this on right now work—into photons. Intel's photonic technology uses a dazzling bit of engineering—and I do mean dazzling, as we're on the scale of your fingernail—to encode data into laser streams. These streams converge into one, and travel along a fiberoptic strand to their destination, where they are decoded from light back into electrons.
Why would we need anything as complicated and sophisticated as this? The fact of the matter is that we're nearing the limit of what we can do with electrons—and there's no arguing with physics. Once we get in the realm of 10 gigabit transfer speeds, we've pushed copper wiring about as far as it will go without degrading the signal beyond usefulness. And with the mind boggling volume of data swirling around—HD movies, lossless audio, high resolution photos—what might sound excessive today will be essential sooner than we think.
Intel's fiber connection, on the other hand, can take us farther and faster. Immensely so. At the speed Intel has announced today, you could download an HD film from iTunes or 100 hours of music in less than a second. And if they reach their theoretical potential of 1 terabit per second, you could slurp down three seasons of an HD show or backup your entire harddrive in the same amount of time.
Rattner said Intel hopes to have silicon photonics "widely deployed" by mid-decade, though holding one's breath in cases like this is usually a bad idea. We asked Intel, after hearing them tout the advantages silicon photonics offers for consumer devices, whether we could expect to see this technology replacing USB within this timeframe, prompting them to stress that the significance of the breakthrough is in its potential, not its concrete applications—commercial adoption will hinge on the market and manufacturing factors. Still, they have proven the technology works, and works well. For now, I can safely say that they have preemptively ruined USB 3.0 for me. [Intel Silicon Photonics Research]
發 表 於: 2010.07.30 12:25:46 PM
英特爾:矽光連結技術,可將資料傳送至更遠的距離,且速度較現在的銅線更快。
將是雲端運算的利器
發 表 於: 2010.09.15 11:22:41 AM
感測系統新發明 「光纖」 品質佳
〔記者洪定宏/高雄報導〕傳統電訊感測系統監控橋梁及邊坡異狀時,很容易受到電磁波干擾而故障或誤判,為改善此一缺點,國立高雄大學電機工程學系教授施明昌與土木與環境工程學系主任俞肇球運用光纖傳導特性,開發出光纖感測系統,不但精準迅速,成本更只要國外類似產品的一半。
施明昌和俞肇球用新一代光纖「光閘(Grating)」技術,原理類似光線照進百葉窗所產生的光影明暗變化,當明暗間隔出現不正常的變化,意即監控點將發生危險,可發出通報及早應變。
施明昌表示,傳統感測器多採電子式感應,以銅質電纜線佈線,容易受電磁波干擾出現誤判狀況,或因埋設位置潮濕短路故障。
此外,接收設備的操作介面未中文化、不夠人性化,以及程式封閉無法再擴充也常令人詬病,若送到國外維修,往返至少耗時兩星期。
施明昌強調,光纖相對比銅線便宜,且不像銅線會因鏽蝕造成短路,不受電磁波干擾品質相對穩定。
目前實驗室測試可佈線達10公里、30幾個點,技術開發由施明昌主導,信號判讀由俞肇球負責,接收器及感測器均可自主開發,不僅技術不再受制於國外廠商,還能針對不同需求客製化。
發 表 於: 2010.09.20 12:09:01 PM
速度有望達 100Gbps:英特爾在以色列國防軍繼續展示光峰光纖接口
來自:驅動之家
    以色列國防軍 2010上,英特爾繼續展示著自己極為看重的光峰光纖接口技術,並擺放了兩套演示平台。
光峰技術是在整整一年前的以色列國防軍 2009上首次宣布的,由蘋果提出創意,英特爾具體開發,目前傳輸速度高達 10Gbps的,未來更可提升至100Gbps,而且單條線纜同時支持多種不同協議,並支持菊花鏈,延遲也很低。在英特爾的規劃中,光峰值將在未來一併取代USB接口,HDMI接口,DisplayPort的等各種傳輸接口,事實上這也是英特爾遲遲不肯原生支持的USB 3.0的重要原因之一。
這次的第一套展示系統重點是一台仁寶代工製造的筆記本,與一台的Avid高清的I / O轉接盒相連,另外還有一個配備輕山頂接口的西部數據外置硬盤,一個 HDMI接口適配器,同工傳輸 1080p的全高清視頻,走遍的戴爾顯示器還在播放另一端未經壓縮的視頻。
英特爾解釋說,光峰可以讓 Avid公司轉接盒將不同協議的控制轉交給仁寶筆記本軟件,充足的帶寬則可以輕鬆傳輸未壓縮的超高碼率高清視頻,無損音頻。
光峰,HDMI接口轉接盒再次登場,不過看起來比以前小多了,現在基本和一張信用卡差不多,而且也沒有外置輔助供電。
發 表 於: 2010.11.17 11:26:31 AM
光纖上網成主流 用戶數超越ADSL
http://tw.news.yahoo.com/article/url/d/a/101117/52/2h8um.html
關鍵字: FTTB   台灣大寬頻   資策會   電電公會   翁樸山   網際建構與管理
MHL聯盟:用最簡單的方式 解決最複雜的問題
銀色台灣的危機與轉機
IPv4位址將耗盡 台灣應加速IPv6過渡步伐
民國100年 中小企業現「蟲蟲危機」
十巨頭打造真實雲端體驗 醫療雲打頭陣
國際AI治理熱潮崛起 主權AI成全球焦點
資策會攜手學界啟動南臺灣生成式AI教育合作
學研界攜手以AI技術提升碳中和園區、養生村創新服務
Rohde & Schwarz 行動通訊測試高峰會聚焦無線通訊最新發展 – 現已提供線上回放
精誠「Carbon EnVision雲端碳管理系統」獲台灣精品獎銀質獎 善盡企業永續責任 賺有意義的錢
一次到位的照顧科技整合平台
技術認驗證服務多建置 協助臺產業建立數位創新生態
生成式AI刺激應用創新 帶動軟硬體新商機
人工智慧產業化 AI PC與AI手機將成市場新寵
5G無線電網路:未來工廠的核心
