發 表 於: 2010.08.03 09:33:31 AM
文章主題: Google TV怎麼用?
Google TV就是把電視當成瀏覽器一樣吧我想!
發 表 於: 2010.08.12 10:54:03 AM
文章主題: Re: Google TV怎麼用?
蘋果將推出新一代的Apple TV正式更名為iTV(網路互動電視)
據可靠消息確認,蘋果將要推出新一代數位機上盒,售價 99美元。他的大小還有結構都和新一代的iPhone差不多,(A4的中央處理器,16GB的閃存)並且將會推出新的iTunes的視訊流服務。遺憾的是,據我們得到的消息,這個機上盒並不能處理 1080i的和1080p的視訊,最高只能支援到720p,原因是A4的處理器並不能很好的處理HD視訊。另外,蘋果會將蘋果電視改名為互動電視iTV,有意思的是,當蘋果的機上盒剛剛推出的時候,他就叫這個名字。
來自:威鋒網(weiphone.com)
發 表 於: 2010.08.17 11:20:33 AM
分析指出蘋果未來兩年推出全功能上網的HDTV
來自:weiphone
美國投行Piper Jaffray公司的著名分析師吉恩週一發表投資者報告時反复強調說,在未來 2-4年內,蘋果計劃推出一款可聯網的全功能高清晰度電視。而下個月推出的新款蘋果電視只是為發行可聯網的高清晰度電視鋪路。
發 表 於: 2010.09.02 12:15:01 PM
惠普推的HDMI無線傳輸器
來自:weiphone
發 表 於: 2010.09.02 07:13:01 PM
APPLE 新推出iTV,就是"愛TV"
Apple Showtime's After Party: Photos of the iTV Livingroom Streaming Box
The iTV set was by far the shining star of the show, hounded by fat, balding, geek paparazzi. The little set top box iTV looks like a half height Mac Mini with the sole purpose of streaming media to a livingroom TV. This is what is known to PC-doods as a Media Center Extender.
Again, it streams those new 640 by 480 pixel movies, music, photos, podcasts, TV shows. There's a power supply inside, USB, 802.11 wireless, Ethernet, HDMI, component, stereo audio, and optical audio out to your TV.
The good news is that even though there's a front row like interface, it looks like it's running fast enough that it won't suck like Apple's sluggish 10-foot interface, Front Row.
Apple's set top streamer won't be in our grubby little gadget mitts until 2007, but we're already asking: Why $299 for something without a drive? I don't know. Call it love.
And we touched it! Jump for some fetish shots, along with some screens. BTW, its a box, so don't expect centerfold-type imagery, mmkay?
(PS, we're not done yet! More posts to come in the next few hours.)
All our iTV coverage at Apple's Showtime [Gizmodo]
All Apple Showtime Posts [Gizmodo]
發 表 於: 2010.09.02 07:57:16 PM
發 表 於: 2010.09.08 10:57:18 AM
三星考慮推出Android系統網路電視機
發 表 於: 2010.09.10 11:36:08 AM
英特爾總裁:Google TV本月上市
發 表 於: 2010.09.30 12:13:00 PM
Apple TV's Guts Contain 8 GB Of Flash Storage
As usual, the folks at iFixIt have torn down the latest Apple gadget. They were happy to find that the Apple TV was ridiculously easy to disassemble and contains the same 8GB NAND flash chip that we've seen in iPads.
According to iFixIt, this is what you should know about the teardown:
* The Apple TV has 256 RAM, just like the 4th Generation iPod Touch and the iPad. The key marking of interest on the A4 processor package is "K4X2G643GE," which is identical to the marking found on the iPad.
* We found Samsung K9LCG08U1M 8GB NAND flash chip inside the Apple TV! It's the same chip we found when taking apart the iPad. This is a pretty remarkable amount of storage for a $99 device.
* We are pretty sure the flash memory is used to cache your favorite shows while they're being streamed.
* There is an empty spot right next to the Samsung NAND flash that looks to be the perfect size for putting another Samsung NAND flash chip. Could Apple be planning a higher capacity Apple TV in the future?
* Wi-Fi board brought to you courtesy of Panasonic! This is the first time we've seen a Wi-Fi board from Panasonic in an Apple device. A different division of Panasonic usually supplies the optical drives for Apple's laptops.
* The Panasonic Wi-Fi board contains a Broadcom BCM4329XKUBG 802.11n Wi-Fi/Bluetooth/FM, exactly the same as the one we found on the iPad.
* The solder pads near the side of the logic board look to be a *perfect* match for a dock connector! This Apple TV seems to be a couple of features shy of a full-on computer. Perhaps this logic board will be used in future iPads?
* Apple is continuing its theme of hiding power supplies inside their devices. It's especially impressive here, considering that the Apple TV is only slightly larger than a 60 watt MacBook AC adapter.
* The sticker on the power supply has this rating: 3.4V @ 1.75A. We'll save you the multiplication: that's just 5.95 watts!
* Apple brags that when in standby mode, the Apple TV uses less power than a night light. We don't suggest trying to use the status LED to illuminate your dark hallways, though.
If you're into gadget gore or DIY repairs, be sure to follow the link to the full teardown for more details and photos. [iFixIt]
發 表 於: 2010.10.20 11:06:32 AM
YouTube的Leanback正式推出配合谷歌電視上架
來自:搜狐的IT
 為配合本週末上市的谷歌電視產品,YouTube的官方博客今天宣布正式推出YouTube的Leanback。youtube或Leanback專為大螢幕電視設計,可以根據用戶的瀏覽歷史和喜好,全屏不間斷播放相關HD視訊。此外還 Leanback提供十個頻道,視頻每日更新。根據科技博客Mashable的報導,谷歌和youtube或都希望通過合作擴大自己的用戶數量。
谷歌在五月份的I / O的大會上就演示過 youtube或Leanback,谷歌希望藉此將流媒體視頻引入家庭影院系統,而另一方面,Mashable稱 youtube或Leanback是專為電視設計的谷歌,YouTube的希望用戶在使用谷歌電視瀏覽網頁時也能方便觀看 youtube或網路視訊。
索尼的電視與羅技谷歌谷歌電視機頂盒歌劇團都將在本週末上架,YouTube上公佈 Leanback可以說是恰逢其時,但此項功能能否得到消費者的認可,還需拭目以待。
發 表 於: 2010.10.22 11:06:03 AM
趨勢科技提醒AI App及惡意內容才是資安防護要點 下半年將推出消費性方案
TrendForce:美關稅壁壘加速轉單 台晶圓廠產能利用率上升
聯發科5G寬頻技術與全球夥伴合作 打造綠色通訊生態圈
Palo Alto Networks融合精準AI安全方案 防禦進階威脅並確保AI技術的採用
Red Hat運用Intel技術強化資料中心至邊緣的AI工作負載
出口管制風險下的石墨替代技術新視野
用Arduino 打造機器人:循跡、彈鋼琴、下棋都行!
樹莓派推出AI攝影機、新款顯示器
以爆管和接觸器驅動器提高HEV/EV電池斷開系統安全性
生成式AI引爆算力需求 小晶片設計將是最佳解方
